It is currently Tue Aug 05, 2025 10:06 pm
PostPosted: Fri Aug 31, 2018 6:00 pm
First name: Alain
Last Name: Gagnon
City: Ottawa
State: ON
Hi folks
I am trying to figure out an easy way to temporarily attach a bridge with a pre-installed saddle to check intonation before permenantly glueung it on. I read this tip from Dan at Stewmac https://www.stewmac.com/How-To/Online_R ... it_on.html
It sounds great but he Doesnt say what he would do if it is in the wrong place. Does he patch the bridge pin holes and try again?
Alain
_______
PostPosted: Fri Aug 31, 2018 6:10 pm
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
Watch this video, starting at the 3 minute mark. I have done this exact thing, and it works fine. It is basically a makeshift tailpiece.
https://www.youtube.com/watch?v=U6KtnjoD1N0
PostPosted: Fri Aug 31, 2018 6:43 pm
First name: Alain
Last Name: Gagnon
City: Ottawa
State: ON
Very nice, easy, and simple. That’s great. I’ve seen others with a similar apparatus that’s way more complicated. This looks easy. Thanks Don!!
Alain
_______
PostPosted: Fri Aug 31, 2018 6:47 pm
First name: Brad
Last Name: Combs
Side question - out of curiosity - is it common to do this when the bridge is pre-slotted? Every instrument I’ve built had the saddle slot routed after the bridge was already attached.
Why would it not just be a measuring activity?
Thanks! Always learning. :)
Brad
PostPosted: Fri Aug 31, 2018 9:00 pm
First name: Freeman
Last Name: Keller
There was an article in American Lutherie in the recent past. Basically the idea was to build a padded channel shaped piece that would fit over the end and act as a tailpiece. A tailpiece applies enough down component to hold a floating bridge in place, it would work just fine for a preslotted standard bridge. Obviously you get a slightly different sound because of the difference in the way a floating and pinned bridge drive the top but it would work well enough to do your intonation and check geometry.
I could go look for the article if it would be helpful.
PostPosted: Fri Aug 31, 2018 9:15 pm
Last Name: Parker
City: Charleston
Brad
Brad—
If someone cuts the slot before gluing on the bridge, I think it is more common that they just measure carefully and/or use a Saddlematic type device to place the bridge for proper intonation. I like using the tailpiece, but I think it is less common. Either way works.
These users thanked the author doncaparker for the post: bcombs510 (Sat Sep 01, 2018 4:53 am)
Users browsing this forum: No registered users and 44 guests
